Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
rectifier brands
Old Oct 18, 2015 | 09:19 AM
Originally Posted by woody64
thanks and this might sound stupid but how do I do that?what setting on meter? thanks
Set the meter on ohms resiatance. You can at least rule the stator out as causing the problem. Just check resistance between each stator yellow leads. Should at least show a small amount of resistance between each yellow with no individual wire shorting to ground. If that checks out replace the regulator.If you could actually find a regulator made in Japan for your Honda you'd be lucky unless you want to pay oem replacement prices and even then they're still probably made else where.
Old Oct 18, 2015 | 02:29 PM
user493's Avatar
Moto Psycho
Originally Posted by hugemoth
There is one common brand of replacement regulator, something like Caltrek, that doesn't hold up. The one I had on my street bike melted down on an Alaska trip which caused some delays. I replaced it with the stock Honda version which has lasted for years.
That would be Caltric. They make starters and a bunch of other stuff too. https://www.caltric.com/
Tomtom86
Aug 7, 2024 07:40 PM
Bratman2
Aug 6, 2022 01:42 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
panicmanic
Sep 20, 2015 05:54 PM
oldschool64
Aug 12, 2015 07:13 AM
