Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
96 sportsman 400 bogs
Old Nov 21, 2015 | 03:49 PM
Jamesmooney's Avatar
Default 96 sportsman 400 bogs
OK guys I have a 96 sportsman 400 and it starts and runs great until I put it in forward and try to go it does the exact same thing as reverse as in reverse has the override button to push and override I call slow mode it acts like it is limited in forward ran fine no problems then just started wasn't slow coming it just happened it's almost like I need to push the override button to go forward what do I check disable replace it can't be major when it's in neutral it revs up normal like it's brand new just retards in forward if it's a safety switch trust me if can can get rid of it I will please help
Old Nov 21, 2015 | 04:16 PM
Pull the fuel tank plastic off.On the left side is the circuit board. At the top of the board is two black wires. One is the cdi kill wire,the other black wire goes to the reverse limiter. Pull the wire leading to the reverse limiter and tape the end of the wire and tuck it out of the way. This should solve the problem on limiting in forward plus you wont have to push the over ride button in reverse to get full power. This was a common problem on limiters shorting out. Some would die when placed in reverse,or would only stay running in reverse with the over ride button pushed. Others would limit in forward range. You'll know real quick if you've pulled the right black wire.. If you can't kill it with the key,then you've pulled the ignition kill wire..
Old Nov 21, 2015 | 04:19 PM
Thank you thank you thank you I'm on it hopefully that gets me going it's gotta be cause it runs to good again thanks
pgamboa
Dec 24, 2023 11:52 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
79hugger
Aug 30, 2015 02:21 PM
mattcraig1
12
Aug 27, 2015 12:23 PM
dwhipper61
Aug 27, 2015 11:01 AM
