Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
04 predator 50 intermittent spark
Old Dec 18, 2015 | 09:00 AM
JOSH_GOON's Avatar
Default 04 predator 50 intermittent spark
Okay ive replaced the stator and the left hand switch block and also tried a known good cdi and nothing solved the issue
the quad will spark but only after the starter button is released and i can ground the black/white wire from the cdi and make it spark consistently
so my question is has anyone run into this and if so what did you do and check and the wire diagram i have isnt very good so im not entirely sure what it is i am bypassing when grounding the black/white wire
also checked the coil that was good
Old Dec 18, 2015 | 09:43 AM
Don't have a later wiring schematic than a 2002,but a black/white also goes to the tethered safety switch. Try bypassing this switch and tying these two wires together and see if you have good spark.
Old Dec 18, 2015 | 09:46 AM
JOSH_GOON's Avatar
I have a black/yellow and green coming from the saftey bypassed that and it didnt fix it but the odd thing is sometimes when wiggling the lanyard the spark will pick up however when bypassing the switch it goes straight back to only sparking once starter button is released
Old Dec 18, 2015 | 09:49 AM
JOSH_GOON's Avatar
I just tried wiggling the lanyard again but this time to effect
Old Dec 19, 2015 | 09:49 AM
Don't know if you have this manual..If not,it may help on the wiring schematic.2004 Polaris Predator 50 Service Manual PDF Download
lucid_dream2
Nov 22, 2015 07:28 PM
hkc3
Oct 19, 2015 08:28 PM
boomerine
Ask the Editor
Oct 1, 2015 06:07 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
