Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
KLF 185 bayou won't idle?!?
Old Dec 30, 2015 | 11:54 PM
huss002's Avatar
Default KLF 185 bayou won't idle?!?
Hi I own a Kawasaki KLF 185 Bayou for some reason it will not idle and when i try to adjust the idle screw nothing happens, at first i thought it was a carb problem so i pulled the carb off went through all the jets un screwed the idle and pilot screw and went through them with carb cleaner anyway the next morning i tried starting it up it fired but still no idle i had a thought that it wasn't getting enough fuel to the engine so i brought a new fuel filter thinking the it was blocked up with gum and it still won't idle if you have any ideas why this is happening please let me know
Old May 11, 2016 | 01:11 PM
BYC's Avatar
BYC
I'm pulling out the cam as I've done everything else. Dollars to Donuts its the "decompressor unit" not releasing and keeping the exh open that slight amount to stop it from idling. I may just pull it out completely.
Old Jun 18, 2023 | 06:45 PM
Maw917's Avatar
Default Any luck
Did you have any luck figuring out the idle issue. Small thing here. Also, what do you mean the decompression unit?
cjben
Apr 14, 2019 11:10 PM
technetnerd
Oct 24, 2012 06:29 PM
Drewpul
1) Engine problems..
8
Jul 26, 2011 07:46 AM
BigWaynester
Apr 24, 2004 09:46 PM
MikeyM
May 22, 2000 11:24 AM
