How to adjust Idle on Yamotto
Old Jul 17, 2011 | 07:41 PM
Drewpul's Avatar
Default How to adjust Idle on Yamotto
I just recently put a new engine in my 05 Yamoto. I've tested it out and it runs pretty well. I adjusted the carb to the recommenced settings, and got it to idle but only for a few seconds before it turns off.
Is there another adjustment I should be trying???
Thanks
Drew
Old Jul 19, 2011 | 03:03 PM
Jaster94's Avatar
i reckon if you've adjusted the screw that's near the throttle spring on the side of the carb, i might lean towards your idle jet being plugged up or nearly plugged up. does it try to idle at really low RPMs or will it just not idle at all?
Old Jul 20, 2011 | 07:40 AM
Drewpul's Avatar
It tries to idle at really low RPMs.
Old Jul 22, 2011 | 09:41 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The fuel screw has a affect on the idle also.. most fuel screws are sticking out the bottom of the carb...
Old Jul 22, 2011 | 02:07 PM
KTM Patrol
Former Chinese POW!
The fuel screw and the pilot jet work together from about idle to 1/4 throttle.. they control the fuel.. A larger pilot jet will need less turns out from seated when you set the fuel screw.. most fuel screws are set at 1 1/2 turns out from seated...if it runs best at less than 1/2 turn out from seated.. you need a smaller pilot jet.. any more than 2 1/2 turns out from seated and you need a larger pilot jet... but to be honest if it runs best at 3 turns out and its from China... Id be happy and leave it there..
This is only for 4 strokes..
On a 2 stroke its a air screw(not a FUEL screw) and everything I said is the opposite for it..except that it is good for idle to about 1/4 throttle.
Old Jul 22, 2011 | 07:02 PM
Drewpul's Avatar
Thank you very much. We will give it a try.
Drew
Old Jul 25, 2011 | 08:11 PM
Drewpul's Avatar
We found the Fuel Screw and it is very difficult to reach. Is there a special tool? We tried using a long set of needle nose pliers but it does not work very well.
Old Jul 26, 2011 | 12:17 AM
Jaster94's Avatar
if it's up underneath towards the front like others i've seen, you can use a flexible 1/4" drive extension with a 1/4" socket to drive a screwdriver bit to reach it. i've done that before.
Old Jul 26, 2011 | 07:46 AM
KTM Patrol
Former Chinese POW!
I have used needle nose pliers... the side of a screw driver... and have even taken the carb off made the adjustment and put it back on...
Jaster94 has a good idea...
Divergent12
Aug 19, 2023 05:26 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
MNatv89
Jul 7, 2015 11:36 AM
