Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2003 Polaris Sportsman 90
Old Feb 5, 2016 | 11:24 AM
amalota's Avatar
Default 2003 Polaris Sportsman 90
New to the site. I ordered a replacement carburetor for 2003 Polaris Sportsman 90. When I received the new one, the vacuum fitting had broken off during shipping. Can this entire brass fitting be removed and replaced, or is it molded into the body of the carb? Also, if I install the new carb without hooking up this vacuum tubing, what are the implications? Another new carb is on the way. But, I really wanted to install the part this weekend to see if it fixes sputtering and poor idling issues. If I install the new carb with the broken vacuum fitting (until the new, new carb arrives), what will likely be the risk? Please share your expertise. Thanks in advance.
Old Feb 5, 2016 | 01:35 PM
If it's the brass barbed fitting on the side of the carb it's not a vacuum line but the oil injection nozzle.. Only way I'd crank one up this way is to have the fitting blocked off and the fuel premixed 40/1. If it's the capped vacuum on top that's not used anyway but if it's broken off,just temporarily place some tape over this area to try out the carb.
jonwolf5400
Nov 27, 2015 10:18 AM
brian350
Nov 25, 2015 04:05 AM
Matthew30
Nov 22, 2015 03:22 PM
SecrtAgnt
Nov 13, 2015 01:57 PM
jonwolf5400
Nov 12, 2015 06:25 AM
