Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Warn Winch wiring
Old Jan 9, 2017 | 09:55 PM
Salmon's Avatar
Default Warn Winch wiring
Older warn winch with 4 post solonoid dial switch can't figure out how to wire handle bar switch. Can I go thru the solonoid or thru the dial switch? Handle bar switch has 3 wires.
Old Jan 10, 2017 | 06:27 PM
Kymco 450i's Avatar
One wire goes to ignition switch on/off so it cant be run without the key on, other two to solenoid, that is the way my KFI is run. From what I have seen they all seem to be the same.
Old Jan 10, 2017 | 07:11 PM
user493's Avatar
Moto Psycho
I don't think it will work with both switches hooked up. I would toss the dial switch in the trash if the handlebar switch is the right one.
Old Jan 10, 2017 | 07:19 PM
Kymco 450i's Avatar
Didn't catch the part about the dial switch....not familiar with that. On my KFI I have a dash switch and added a remote switch and it was just a plug and play except for that darn ignition wire that took hours to snake thru the frame.
Old Jan 10, 2017 | 07:28 PM
Salmon's Avatar
Thanks for the input, will try with out the stock switch.
Old Jan 11, 2017 | 08:07 PM
dbj216's Avatar
Back Country Explorer
The Warn Installation Guide, page 7, has a pictograph that roughly describes the basic wiring of a winch install.
It may help you...
https://www.warn.com/atv/winches/pdf/89294A0_rs.pdf
David
