how to load 2 atv's on 5x10 trailer?
Old 05-13-2004, 10:52 PM
Roostr19's Avatar
Default how to load 2 atv's on 5x10 trailer?
Hi, I have a 5x10 utility tariler with no back and was wondering how to haul two atv's safely. I have a Yfz450 and a 400ex. Both wheelbases are too long to haul turned sideways unless I hang the tires over the edge. Is there a way to safely piggyback them?? Or any other ideas???
Thanks.
Old 05-13-2004, 11:42 PM
tencubed's Avatar
Being retired is a hoot!
one at a time? [img]i/expressions/face-icon-small-smile.gif[/img]
Old 05-14-2004, 09:31 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Maybe a simple mod to the trailer?
Depending on how high your front bed rails are, you could add two wooden ramps up front so the front bike could ride up on them. This would put the front bike up on an angle with a little bit of it overhanging the tongue. You'd need to make sure that your tow vehicle could handle the extra tongue weight
Same idea except out the back - bolt on just enough of extension ramps to hold the second quad. You've got to be careful with this one, too much weight behind the trailer axle and you'll loose tongue weight and start to fishtail at speed.
Only other way would be to bolt on four skids (2x10's or 2x12's) sideways across the tops of your trailer side rails, two for each bike. Then you could load then sideways. Makes for a taller trailer load and you'd need to be extra careful about strapping them down, but it should work.
Jaybee
Old 05-14-2004, 05:32 PM
rescuediver's Avatar
Roostr, go to the "Gallery" button towards the top of the page, go to the "T" section and look at Treedoc's pictures. He has a trailer just like jaybee described. Lt. Dan
Old 05-14-2004, 05:33 PM
And Roostr, Welcome to the forum[img]i/expressions/face-icon-small-smile.gif[/img]
Old 05-19-2004, 09:10 PM
quadracer18's Avatar
I defenetly wouldn't piggy back them..since they don't have racks....my buddy has a 5x10 and we can fit my scrammy 500 and a trailboss 330 in it...on the front of the trailer were the tongue is...we just hang the front end of one quad over the rail...that gives enough room for the second quad on the back...then just strap the crap out of them.....works for us just fine..
quadracer
Old 05-20-2004, 08:01 PM
SCOOT400EX's Avatar
Stand the 400ex up on its grab bar then put the 450 right behind it.
just my 2 cents
Old 05-20-2004, 11:54 PM
deanz400's Avatar
same problem i had , i have a 4x8 trailer and made some metal ramps to bolt on over the front rail by about 2ft and added a foot extension to the back . i made the trailer with a longer tounge then normal so the extensions were easy now i can carry 2 or one wheeler if going for a quick ride , food for thought..
Old 04-23-2020, 09:30 AM
MCRaptors's Avatar
Thumbs up Your 4 x 8 Trailer
Hi Deanz400,
I was reading your thread about you upgrading your 4 x 8 trailer to fit 2 ATV's. I'm in the same situation right now. I wanted to ask if you could please email me pictures of the trailer from a few angles and any custom work you did as I need to do the same. Thanks so much.
Old 06-07-2020, 06:45 PM
Originally Posted by MCRaptors
Hi Deanz400,
did you get the pictures? I’d like to see how I can fit two 700 Grizzlys in my 14ft enclosed trailer.
Quick Reply: how to load 2 atv's on 5x10 trailer?
