Hummer H3
Did a search for Hummer on here and no hits. My 2001 5.4 F-150 supercrew is getting on up there in miles, and I dont really need the truck bed no more, so I was thinking of getting a Hummer H3. You really cant beat the price. I payed close to that price for my current truck. Anyway. Any thoughts on them, as far as towing and such.
Not sure what they are rated to tow,but it can't be too much. Probably in the range of 2,000 to 3,000 lbs tops. The H3 is based on the Colorado/Canyon PU and is very underpowered - only available engines are the I-4 or I-5. Although the I-5 puts out decent power for it's size, going from a 5.4 V-8 to an in-line 5 cylinder will be a shock.
Jaybee
Jaybee
The H3 has high ground clearance, high approach and departure angles and a really low, low crawl rate - giving it some decent off-road abilities - especially when compared to most small to mid-sized SUV's. Other than that, it's just a mid-sized GM SUV that gets by on the Hummer image.
Jaybee
Jaybee
i only like the h1..h1's are true hummers..then h2 are nice..but the h3's look like S^&*!! like common..least they could do was make it look half decent...or put it on a full size chevy fram and not a colorado frame..like hummer could make good money if they would make another true off-road vehicle..but it still b a casual around town truck too..like the look of an h2 but the set up of an h1
jsut my thoughts
jsut my thoughts
ENGINE
TYPE: Vortec 3500 3.5L
HORSEPOWER: 220 hp @5600 rpm (SAE)
TORQUE: 225lb.- ft.@2800 rpm
GOVERNOR TYPE: Multi-point sequential fuel injection
DISPLACEMENT: 211 cu.in.
BORE AND STROKE: 3.66 x 4.00
COMPRESSION RATIO: 10.0:1
CRAWL RATIO:
BASE VEHICLE: 45.0:1
WITH OPTIONAL OFF-ROAD SUSPENSION PACKAGE: 68.9:1
FUEL CONSUMPTION:*
MANUAL TRANSMISSION: 16 mpg city / 20 mpg highway
AUTOMATIC TRANSMISSION: 16 mpg city / 19 mpg highway
TRANSMISSION
Standard 5-speed manual or optional Hydra-Matic 4L60-E
4-speed automatic
DRIVETRAIN
2-speed, electronically controlled, full-time 4WD
TRACTION CONTROL SYSTEM (TCS)
Brake-controlled, single-wheel control capability with rear axle
electronic locking differential
STEERING
Power-assisted, rack-and-pinion, with tri-brushing
mount design
BRAKES
Electro-hydraulic power 4-wheel disc, 4-wheel anti-lock,
4-piston opposed front caliper / single-piston sliding rear
caliper with Dynamic Rear Proportioning
FRONT SUSPENSION
Independent SLA torsion bars, 46 mm, monotube gas-charged
shocks and 36 mm stabilizer bar
REAR SUSPENSION
Multi-leaf, semi-elliptic dual-stage leaf spring, 46 mm,
monotube gas-charged shocks and 25 mm stabilizer bar
FRAME
Welded steel
WHEELS & TIRES
16 x7.5 in. aluminum wheels, 32 in. P265/ 75R16 all-terrain
tires with full-size spare tire
PERFORMANCE
TURNING CIRCLE: 37 ft.
GRADE CAPABILITY: 60%
SIDE SLOPE CAPABILITY: 40%
WATER FORDING DEPTH: 24 in.@5 mph; 16 in.@20 mph
VERTICAL SCALING HEIGHT: 16 in.
* Estimated mpg 16 city/20 highway based on GM testing.
Official EPA not yet available.
2006 H3 STANDARD & OPTIONAL EQUIPMENT
STANDARD INTERIOR EQUIPMENT
OnStar® with 1-year Safe & Sound service plan NOTE 7
Power windows, including “express down” driver window
Power door locks
Dual front air bags with Passenger Sensing System NOTE 8
Seating for 5
Cloth seats
Fold-down 60/40 split rear seats
Remote keyless entry with panic button
Electric rear window defogger
Manually controlled front air conditioning system with electronic controls
AM/FM stereo with CD player
TheftLock for RDS radio
Driver information center with up to 26 alerts
StabiliTrack Stability Enhancement System
Traction control
Content alarm anti-theft system
PASSLock® anti-theft vehicle security system
Battery rundown protection
Two 12-volt auxiliary covered power outlets in front; one covered outlet
in the rear cargo area
Tuff-Floor rubberized flooring in cargo area
Five assist handles
Cruise control
Electrochromic rearview mirror with 8-point compass, outside temperature
display and OnStar controls
Retained accessory power
2.64:1 2-speed transfer case
STANDARD EXTERIOR EQUIPMENT
One-piece swing gate with assist strut
Swing gate mounted full-size spare tire
Fog lamps
Rear bumper with recovery loops
Daytime running lamps
Dual composite halogen headlamps
Underbody protection
Front and rear recovery hooks
4-wheel disc brakes with ABS
Tire pressure monitoring system
OPTIONAL EQUIPMENT
Head curtain side air bags NOTE 8
Sliding glass sunroof with “express open” and “express close”
DVD Navigation System
Lighted visor mirror with HomeLink® (available on Luxury Package only)
Hydra-Matic 4L60-E 4-speed automatic transmission includes StabiliTrak
Chrome Appearance Package (Includes door handles and mirror caps)
Trailer hitch and wiring harness
Engine block heater
16 x 7.5 in. chrome wheels with standard 32 in. wheels
Front and rear carpeted floor mats
In-dash 6-disc CD changer with AM/FM stereo and premium
7-speaker Monsoon® sound system
AM/FM stereo with single, front-loading CD and MP3 disc-playing capability,
plus premium 7-speaker Monsoon® sound system
Off-Road Suspension Package (Fully locking electronic rear differential, 4.03:1
2-speed transfer case, 33 in. LT285/75R16C on-road/off-road tires)
XM Satellite Radio NOTE 9
ok, a little underpowered and it is no speed demon but i know a few with them and it really appears to be solid-with decent snappiness. has huge leaf springs and stuff- way more heavy duty than the gm trucks. crawl under one and look. its still a very meaty vehicle even though its the smallest hummer. but i dont think its a bad deal. dealers will let them go very nicely equipped for the upper 25-28K range. the H3 will be going thru mud holes and more rigorous terrain when your (and my) Z-71 is looking for someone to pull us out. if GM would just get rid of this insane 5 cylinder crap and stick the inline 6 in it would be a better truck. havent heard of any quality problems yet either, unlike the canyons/colorados. id get this or a 4runner with the 245hp v6.
CRAWL RATIO:
FUEL CONSUMPTION:*
TRANSMISSION
4-speed automatic
DRIVETRAIN
STEERING
mount design
BRAKES
FRONT SUSPENSION
REAR SUSPENSION
FRAME
Welded steel
WHEELS & TIRES
PERFORMANCE
Power door locks
Seating for 5
Cloth seats
Traction control
Five assist handles
Cruise control
Fog lamps
OPTIONAL EQUIPMENT
Engine block heater
Just joined the Forum so this is my 1st post, but I have to speak up and defend the H3...We bought one in Nov 2005. I wasn't thrilled about the 5 Cyl Motor, but it was time to give up our gas guzzling Suburban...
I did Lots of research before we bought and was impressed with everything but the engine power...Test drove one with the idea we would compare it with some other SUV's we were interested in...I was very impressed...No its not an H1 or an H2...But, we wanted something smaller that still isnt afraid of going Off-Road...and doesnt cost $140K like its big, bad brother Alpha H1...
The Low-end power is nothing like our 6.0L 'Burb, but on the Top-end it gets up and goes... We decided to buy 1 that day...Since then we have taken it on several road trips and just got back from Pismo...
I hauled my Quad Trailer and 2 quads down there with no problems at all...Then we took the H3 out into the Dunes and played...It had absolutely no problems in the Dunes at all and I pushed it hard...
Any doubters can go to Hummerhub.com and look at the posted Pics from 2/11 and 2/12-Not a Plug [img]i/expressions/face-icon-small-happy.gif[/img]
Ours is the Boulder Gray(Almost Tan) in the Pic's.
