Parker Performance Trailer ground?
Originally posted by: SAshton
When I hook up my lights they won't work until I mount the trailer to the truck. Is that normal?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
The end was cut but he said it was a 4 pin. I wired an end and there is a ground wire mounted to the trailer frame but the lights only work when hooked up? I was told that it is supposed to be that way. the ball completes the ground on the trailer. Also the front side running lights dont work(disconnected due to a short) I hooked those up to the taillight wire and blew the fuse.
You never want to ground with the ball ... you must have a wired ground from the truck to the trailer.
Even better is a ground from the battery - all the way to the trailer lights via wire ... you lights will be MUCH brighter.
Also ball ground will cause your lights to blink on and off as you drive.
I do have a ground on the trailer as well but maybe its not a good connection. If the trailer has a ground to the trailer frame then the lights should work when not attatched to truck right? Maybe my trailer ground is bad?
Johnny Mac
60
Dec 14, 2019 06:13 PM
badgerboy1
Sep 26, 2017 06:11 PM
Sep 30, 2015 01:37 AM
