99' Grizzly 600 problems
Old Jun 4, 2004 | 07:10 PM
grizzlysrock's Avatar
Default 99' Grizzly 600 problems
My 99' Grizzly 600 use to go 55-60 mph until i took it through the mud and got stuck. The water was up to the seat when i was stuck and it took a while to winch it out so mud got inside by the belt. After getting stuck it only went 30 mph so i replaced the belt, ckeaned out the inside where the clutch and belt are, and cleaned out the air filter. It can now go around 35 mph which is not normal. Please Help!
Marcus
Osceola, Wi
99'Grizzly 600 stock
97' Big Bear 350 stock
Old Jun 8, 2004 | 09:37 AM
Thunderbolt's Avatar
Did you change your engine oil ?? If you had it in water that deep I would !! Does it start running crappy such as backfiring or does it just not go ?? You could have gotten water in some electrical connections.
Old Jun 8, 2004 | 11:19 AM
Yes i changed the oil. It runs perfect. It has a lot of low end torque but once i get going around 35 it wont go any faster. It sounds like i'm stuck in like 4th gear and it wont go any faster.
-Marcus
99' Grizzly
97' Big Bear
Old Jun 8, 2004 | 11:36 AM
Did you use Grizzly grease on the clutch ? I was told anytime the clutch is serviced Grizzly grease must be used.I have never had one apart so hopefully someone else on here has some more help for you.
Old Jun 8, 2004 | 02:27 PM
No i didnt use it, i didnt really take the clutch apart so i'll try that. Thanks!!!
-Marcus
99' Grizzly
97' Big Bear
Old Jun 11, 2004 | 10:26 AM
Starky's Avatar
Did you find your problem? I was wondering if your breaks or maybe a bearing was sticking.
Old Jun 11, 2004 | 10:34 AM
my fourwheelers are up at my cabin so i'm planning on taking the clutch apart on sat. I tell you once I find the problem. i dont think it has anything to do with the breaks because it has a lot of low end torque and it doesnt hold back untill i get going around 30.
thanks
Marcus
99' Gizzly 600
97' big bear 350
Old Jun 11, 2004 | 10:51 AM
I would be willing to bet you will find the problm in your clutch. Something is hanging up.
Old Jun 14, 2004 | 10:13 AM
ok i'll take the clutch apart this weekend. Thanx
Old Jun 19, 2004 | 06:09 PM
6513's Avatar
good luck!!![img]i/expressions/face-icon-small-smile.gif[/img]
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
hondarider1234
Jul 21, 2015 11:53 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
