Tire question
Old Sep 6, 2004 | 09:58 AM
4xZuk's Avatar
Default Tire question
I've been thinking about replacing my 25's w/ some +1 Mud lites. I there any ~real~ advantage, or should I stick w/ the 25's(mud lites)?
Old Sep 6, 2004 | 02:29 PM
Glenlivet's Avatar
25" and under mud-lites have 7/8 inch tread lugs while the 26" and over have 1 1/16" lugs. Your choice. Both work well.
Old Sep 7, 2004 | 08:10 PM
03250bayou's Avatar
if you dont mind the power loss go with the 26's if your gonna be mudding alot...like glenlivet said...the lugs will be bigger...
Old Sep 7, 2004 | 09:43 PM
PINKMOON's Avatar
Hi. If you mostly ride in mud and swampy wet stuff go for the 26" but if you ride a lot of logging roads , trails and woodlands with the some mudding here and there the 25" might be better suited
Old Sep 7, 2004 | 10:49 PM
maddog56's Avatar
I put a set of 26" mudlites on my rancher and it was the best thing I had ever done to any utilty atv ever. I would stick with the 25" if you are going to be doing mostly trails though.
Old Sep 8, 2004 | 10:08 AM
DKNARND's Avatar
The 25's are a very good trail tire and I ran them for a year before going to the 26's and I have found that the 26's are even better as a trail tire. One suggestion I would have if you are mostly a trail rider is getting the 9" wide front tire instead of the 10" tire. The 26" Lites only measure up to 25 3/8" with 5psi in them.
Old Sep 9, 2004 | 02:02 AM
quadduck's Avatar
I have an eiger auto, how does the 26" tires do on hill climbs, as far as power loss.
Old Sep 9, 2004 | 12:07 PM
DKNARND's Avatar
If you are changing from a stock tire you will notice some loss of power at acceleration with the larger tires. We put 25" BigHorn radials on my brothers Eiger auto and noticed a difference on the low end but not enough to bother him. The 26" Lites will measure up to 25 3/8in with 5psi in them so they are the same height as the BigHorns and weigh about the same. If you install the larger tire you will probably want to install a clutch kit in the future and then you will regain your lost low end, but it is rideable without the clutch kit and you will find yourself using low range more.
Old Sep 11, 2004 | 10:10 PM
4xZuk's Avatar
We went riding today, and you know what? My 25 Mud Lites did fine. I guess I'll probably wait 'til they completely wear out then get some 26's- and clutch kit, and a slip on, and a bore kit, and..................
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
