Plows, which to get?
Old Jan 22, 2005 | 04:14 PM
  #31
duramaximizer's Avatar
Default Plows, which to get?
get a V plow ...i know there is a company that makes one it is cycle country i believe get that!
IMO it is the cat's meow!
Old Jan 22, 2005 | 05:51 PM
  #32
loki2's Avatar
I do not think that they make one big enough. It would have to be wider than the Rhino. and I do nont think that it is strong enough.
Old Jan 22, 2005 | 07:03 PM
  #33
WhiskeyTangoFoxtrot's Avatar
I do not have experience iwth other ATV plows but I have a 60" Moose plow with the small electric winch to raise and lower it. After using it for the dirst time tody I could not be happier. I think that the weight is just right and the two plowing trips around the neighborhood I made today showed it to work fine in both light powder and the heavy wet stuff. Tripped the plow once and it functioned flawlessly.
My son follows int he Rancher with shovels and he angles the plow for me as needed. He's a great kid; that's why he got a new Rancher!
On a separate note, does anyone know anything about a drag box type plow that would go behind the ATV for those places where you would othersie have to back-blade?
Old Jan 22, 2005 | 07:47 PM
  #34
RicksRR's Avatar
thats what I did the other day with my boy...I would say "ok now angle to the left a little" [img]i/expressions/face-icon-small-happy.gif[/img]
he dont mind a bit as long as he's not doing the big shoveling [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 24, 2005 | 10:04 PM
  #35
BigBaller's Avatar
I have a 2001 wolverine and I want to get a 48" warn snow plow and a mounting kit.. I have a 1500 super winch on it. What else do I need to make the whinch pull up the plow and where do i hook the whinch on to.?
Old Jan 24, 2005 | 10:16 PM
  #36
RicksRR's Avatar
they show you that in the instructions..Usually take off your hook and I use a pin through a bracket and its hooked! (And mine is a Warn) pretty quick way to do it, incase I want to hit the trails and through my hook back on...just 3 pins and the plow is off and Im ready for the trail[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 24, 2005 | 11:07 PM
  #37
BigBaller's Avatar
are there specific instructions? because im not to sure about what you mean by taking off the hook and putting pins through the bracket. Do you mean the bracket of the whinch? IM CONFUSED! LOL[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 25, 2005 | 02:44 AM
  #38
loki2's Avatar
There is usually a hook on the end of your winch cable that can be removed by a clevis pin. Take the hook off, and then use a shackle to attach the loop in the end of the cable to a point on the plow. If you use the hook, it willl come off if you are not careful.
Old Jan 25, 2005 | 04:30 AM
  #39
RicksRR's Avatar
well said...I was pretty slack on description haha
I can take a picture of mine and post it in a few hours,if that will help also
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 25, 2005 | 06:52 AM
  #40
loki2's Avatar
How do you post a pic to this forum??
Another hint for happy plowing is to carry a papir of cable clamps, small Ubolts, that fit inot a small saddle for holding cable. Then if you should break your cable, you just make a loop, put on the two clamps,and you are off plowing again. I keep a special cable for plowing that has been broken several times. I change them out when the plowing season in over. Becareful when playing with the cable, it really will get sharp little splinters taht will cut the hell out of your hands. Gloves are very important!!!
Happy Plowing!!![img]i/expressions/face-icon-small-cool.gif[/img]
