OK to run winch when submerged?
Old Jun 14, 2005 | 07:18 PM
RedGoblin's Avatar
Default OK to run winch when submerged?
Originally posted by: RidinLCWA
My brother works for Warn (building winches). They keep samples of every winch submerged in a tank. Every so often they will pull one out of the water tank and test it. He has yet to see one that did not work perfectly when coming out of the tank. After the test, they put the winch back in for additional "conditioning."
2500 included?
Old Jun 15, 2005 | 02:20 AM
Ratchet11's Avatar
Former Sponsor
Ok, OK OK....
Here is the straight straight scoop from a guy who has worked there 16 years...............
The 2.5 or 2500 # winch IS NOT SEALED..... whe you take it for a swim you should ALWAYS at the end of the day,,, run out 20 ft or wire rope, then wind it back in...
this will disapate the water that has gotten into the motor area.. If you do this often then yes, you will have to take it apart and "service" the unit like that other did via the dealer...
PS, on the 3.0 the motor is not sealed and needs to have the same thing done when going for a swim.... only the gear train is sealed.....
Winch on brothers.,....... Glad to hear that it got you out ......
Old Jun 16, 2005 | 09:21 PM
ridinsmooth's Avatar
you can run the winch when submerged.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
