87 Suzuki NO Spark
Old Jun 4, 2005 | 08:54 PM
AdirondackGal's Avatar
Default 87 Suzuki NO Spark
Hi guys,
I sure hope someone here can help me. I have a 87 Suzuki LT-4WD 250cc that is giving me a bad time. A while back it was giving me a problem starting. I checked the spark and it was weak. Then it decided to start for a few weeks, then wouldn't start again, then would start. Frustrated, I loaded it on the truck and took it to the dealer to see what was wrong with the darn thing. They said they couldn't get it started to test it, and if I wanted to pay them by the hour to trouble shoot it it could be quite expensive. Well, because I don't have a lot of money I said forget it and picked the ATV up after paying almost 100 dollars for nothing. I got it home dumped it off the truck and it started right up! So, I thought electrical short. I checked every wire in it front to rear and everything tested okay! I am starting to think it may be the stator. Could this be the problem? I checked the price online and almost died ... 300 BUCKS! I can't gamble on this being the problem for that amount of money. Does anyone have any idea what I can do? I just saw a site in Canada that says they can rewind the stator. Is this for real? Does it work? I sent them an email requesting a price. Hell, it can't cost 300 dollars can it?
I have a lot of property and use this ATV for plowing and yard work. I am lost without it! Can someone give me any ideas what to check or what is wrong?
Thanks for any help!
Adirondack Gal
Old Jun 5, 2005 | 10:47 PM
SPORTSMAN70003's Avatar
I would check and see if I could get a service manual if I were you. It could be a number of things and a manual should help you find whats wrong. For used parts check ebay.
Old Jun 10, 2005 | 10:10 PM
87250xman's Avatar
It could alos be your CDI or ignition coil. Try buying a electrical test unit. Then you can check where your not getting your power. A test unit is about $20 at a hardware or automotive store.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Knackknack
Aug 19, 2015 07:45 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Bulgin88
Aug 1, 2015 06:39 PM
Jul 15, 2015 02:07 AM
