rubicon or rincon
Old Jun 20, 2005 | 08:25 PM
cookoff's Avatar
Default rubicon or rincon
will a foreman rubicon outbog a rincon??..........i have also heard that the hondamatic transmission in a rincon will mess up if u go into water, that true??....any help would be appreciated
Old Jun 21, 2005 | 05:14 PM
Cirviver's Avatar
When you say "outbog" do you mean go better through the mud or do you mean out pull? In the mud, the Rincon does have a slight advantage due to the higher ground clearance of the IRS. If you are talking about pulling power, the Rubicon has a slight advantage due to the low range that the Rincon does not have.
No! Water will not mess up the Hondamatic transmission. It is not a belt. If water does get into the tranny, just change the fluids and keep on riding.
Nondem
Feb 22, 2020 12:20 PM
shimanok2
Jan 29, 2016 07:37 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
