snow plowing (auto or manual)
Catterman, I have both Warn and Cycle Country steel plows. I coated both with the spray on pickup bed liner which stops the snow from sticking to the blade and holds up to blading dirt and gravel.
Rallyrider, I'm not sure who your question is to or what you are asking.
Yellowrider, you should always plow in low range which will raise your rpm's enough to get good clutch engagement so that isn't a problem.
camaross, I would think - depending on how fancy the trailer is - that you should be able to get that setup for under $6000. Does the ATV have any extras like tires, chains, etc? Also, with only 160 miles that engine still needs to be broken in, these 400's don't open up until about 300 miles. It is like a whole new machine.
RallyRider, I don't understand either.
Yellowrider, the Arctic Cat clutch is always engaged, even when not moving. There won't be ANY slipping with it while plowing. Reb2 is right, low range will ensure that RPM's are up. That said, I used "high range" all last winter with no problems.
#16
If the snow is real dry and light the 60" plow will be good, but if the snow is heavy and wet you are better off with a 50" plow. Better to make one extra pass than to make your quad work that much harder.
#17
RallyRider05, I don't understand the ways of the clutch, but the Arctic Cat is always engaged (I think the Yamaha is too) and kept tight, therefore less chance of slipping and longer belt life. Do a search in the Arctic Cat forum and I am sure you will find something there.
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
