How long do ATV batteries last?
Old Sep 26, 2005 | 01:32 AM
GrnXnham's Avatar
Default How long do ATV batteries last?
We bought 2 Suzuki Ozarks last year.
I noticed at the Suzuki dealer that replacement batteries are fairly pricey for these things. How long can I expect my batteries to last on the quad before they need replacing? We ride at least once/month. Hopefully the battery will last longer than my riding lawn mower battery which goes bad after only about 2 years.
Anyone have the original battery on their quad after 5 years?
Are there any cheaper aftermarket batteries for quads?
Thanks
Old Sep 26, 2005 | 01:36 AM
Curls's Avatar
Mine seem to average between 3-4 years. Walmart has inexpensive replacements for most models.
Old Sep 26, 2005 | 01:57 AM
ThrashAndCrash's Avatar
Hold up.......I can speak from a ton of experience on this..........DO NOT get the walmart batteries...The lead plates are not welded together good enough and in rough conditions they will seperate (battery is junk at that point). IF "Curls" had good luck with them; he got lucky..
Old Sep 26, 2005 | 02:07 AM
Ljay's Avatar
Thanks
You can get good quality and cheaper price of batteries on E-bay, The Yamaha dealer here wanted almost $100.00 for one, I found the same ones on E-bay for $50.00,, The batteries out here in this heat, only last a year or two at the most,,, Your mileage may vary,,
Old Sep 26, 2005 | 02:52 AM
jimmypsp700's Avatar
I agree with curls post.
Mine lasted 5 years and I now got a top of the line AGM battery.
You can get a GEL if in warmer climates.
I highly recommend them.
JIm
Look for an AGM (absorbed glass matt) or a GEL battery. East Penn batteries are hard to beat in price and performance. Use their dealer locator to find a retailer close to you. Just a side note. the guys I get them from aren't in the dealer locator. You might try calling automotive electrical repair places. East Penn makes batteries for several other manufacturers as well. Oh ya, when you buy from them, the money is going to another fine US company.
http://www.eastpenn-deka.com/product...ine_power.html
Old Sep 26, 2005 | 11:00 AM
action450s's Avatar
I just replaced the battery in my Forman (1998) this summer, so it was 7 years old, typically they need to be replaced after 5 years. My opinion is to get a factory battery from the dealer or a better aftermarket replacement. If you go cheap you'll be stuck in the woods with a piece of crap bad battery. I figure if the factory battery held up to frequent winching and cold weather riding for 7 years, then its well worth the $100 for the same quality for another 7 years. Thats less then $20 a year for trouble free service.
Old Sep 26, 2005 | 01:52 PM
Arkiemurph's Avatar
"interstate" batteries have been recommended to me by my local ATV repair guy.
Murph
Old Sep 26, 2005 | 02:35 PM
Hoopie's Avatar
i had my original battery in my 2000 scrambler for 5 years then I got the replacement this spring and my new 100 dollar battery is garbage now! Looking for a replacement now.
Jimmy where did you get your battery?
Old Sep 26, 2005 | 08:26 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Every year I have to add water to my ATV batterys, but with that they will last 5 years.
Old Sep 26, 2005 | 09:15 PM
RacinJason's Avatar
It is not age that determines life of the battery...its maintanence and amount of use
machines that are used quite frequently(more than once a week)tend to have batteries last much longer despite bieng used so much more...if your machines set for any extended period of time buy a battery tender which will shut of and maintain peak voltage for worryfree starting first time out of the garage
as far as quality of batteries go for a Yuasa or a Deka
I just replaced the stock Yuasa on my 01 400ex
