snowplow lifting question
Old Nov 12, 2006 | 08:42 AM
beisel1111's Avatar
Default snowplow lifting question
How do you add the rope to your original cable? Do you just remove the hook and tie on the rope to the cable?
Old Nov 12, 2006 | 09:47 AM
400CatDriver's Avatar
LOL...I've never kept a quad long enough to wear out a winch cable. You must really work that thing hard!
Old Nov 12, 2006 | 09:02 PM
motoxer459's Avatar
this is a good point, i want to put the rope on my winch but i use it the most in the winter can you just add it to the end of the cable and take it off when you need the cable
Old Nov 13, 2006 | 11:06 AM
Reb2's Avatar
I haven't tried attaching the rope to the cable but I doubt there would be an advantage to doing that. With the full 50' of cable on the drum it will tend to ball up which will create problems. The intended use is to pull off the cable and put on the short section of rope.
For me that isn't a problem because I run two winches, one for snowplowing, the other for winching if needed. My snowplow winch is mounted to my down pressure system which takes less than a minute to remove. The other winch is mounted using the Warn Multi Mount system which takes less than a minute to mount so it isn't a big deal to change.
Basically I have setup my atv to be the swiss army knife of atv's. I can attach or remove attachments in a matter of moments to setup the atv for what I want to do that moment. My pictures will give you an idea of what I mean.
Old Nov 13, 2006 | 11:24 AM
  #15
zorro700's Avatar
I always thought it would be a great idea if they made a winch with some kind of clutch setting like a cordless drill. When plowing you only need to pick 100# or so, so why don't they make a winch with a..........................say 400# stop or clutch or something, that way you don't put all 2500# of tension on that cable all the time.
Oh and to answer the original ?, just keep using your cable, I snap mine about twice a winter. I just lose about 2 ft of cable, retie and keep going. I think my winch cable is about 40 ft. now instead of 50 ft., big deal.
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
