Lets talk tire weight and diameter a bit
Old Mar 18, 2007 | 08:44 PM
Wolvydude's Avatar
Default Lets talk tire weight and diameter a bit
Originally posted by: montyh one trick to save some weight is to use the narrower front tires on all four corners.
I rode around for over a year with just such a set-up, 24x8-12 on all four corners. It was a very light weight set-up and worked very well...
Old Mar 18, 2007 | 10:52 PM
oldturtle's Avatar
Originally posted by: Wolvydude
I rode around for over a year with just such a set-up, 24x8-12 on all four corners.....
Say Wolfy, were you running the 8 inch tires on stock Yamaha rear wheels that came stock with 10 inch tires? If so any issues with 8 inch sidewalls on the wide wheel. I have often thought about going this route of 25x8-12 Bighorns on all wheels. Reason is weight savings and easier to pick through rocks and ruts.
Old Mar 18, 2007 | 11:34 PM
Wolvydude's Avatar
No, I was running 12x7 DNA aluminum wheels front and back with the 24's. When I first started riding with that set-up I was more than a little worried about rolling a bead off the wheel (the tires were in fact only 7 1/2 inches wide), but it never happened and I tried (unintentionally) many times. Turned out to be a real nice set-up. I still have the DNA's and 24's ready to roll, I keep them as a back-up to my current set.
Old Mar 20, 2007 | 02:47 PM
oldturtle's Avatar
Thanks Wolfy. My guess is that the stock 700 rear wheels are close to 8-1/2 inches wide for 10 inch tires and that these wheels would be too wide for good performance of 8 inch wide rubber. Probably not the best idea anyway and should just stick to stock sizes. The idea of the lightest and narrowest Bighorn on all 4 corners is interesting to me though and I don't see any negatives for my type of terrain which is high mountains and rocks.
Old Mar 20, 2007 | 07:48 PM
  #15
Wolvydude's Avatar
Why not pick up another set of stock front wheels and run them in the back? Should allow you to run 8" wide tires all the way around (assuming you can in fact put the front on the rear). You could test fit one of your front tires/wheels on the rear just to see how it looks. Just a thought...
Old Mar 20, 2007 | 08:31 PM
  #16
CraZySteve's Avatar
Originally posted by: squeege
You can overcome the power loss easily with jetting/filter/air box adjustments. . I went with 10x12x26 front and 12x12x26 in the back.....I wish I would of went narrower ....hope that helps
So Squeege you wishing you put 26x9x12 front and 26x10x12 in bsck?
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
black_thunder
Sep 7, 2015 01:24 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
