reverse lights on your utility
Old Feb 12, 2009 | 01:06 PM
Default reverse lights on your utility
My 2006 Polaris X2 came with, what they called, work lights. There is a switch on the headlight pod that turns them on. They can be handy when backing up when it is dark.
Old Feb 12, 2009 | 05:51 PM
07redrin's Avatar
ive been thinking more and more bout to just wiring it up to a switch to where i can use them whenever needed
Old Feb 12, 2009 | 09:23 PM
JeffinTD's Avatar
There might be times you want to see behind you when you aren't in reverse.
If you wanted to get really fancy you could probably get a double throw switch with a position for on, off, and come on with reverse...
Old Feb 13, 2009 | 06:17 AM
That would be a great idea JeffinTD. Mine do not come on automatically. It's a manual rocker switch that only works when the quad is running or the key is in the running position.
Old Feb 13, 2009 | 08:25 AM
  #15
07redrin's Avatar
thanks guys so far for the great ideas
Old Feb 14, 2009 | 12:07 PM
  #16
blkedoutsprtsman's Avatar
i put bulbs in and added a rocker switch and walaaa i had lights...lol
Old Feb 14, 2009 | 05:27 PM
  #17
07redrin's Avatar
do you have pics of what you did?
Old Feb 22, 2009 | 12:14 PM
  #18
Oldman800's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JeffinTD
If you wanted to get really fancy you could probably get a double throw switch with a position for on, off, and come on with reverse...</end quote></div>
There is a kit for the Polaris with work lights to make them automatic when you put it in reverse. Also, when you add it, the original rocker switch still works. Quadovator.com has them for about 30 bucks +5.00 shipping
Old Mar 18, 2009 | 12:18 AM
  #19
chuck_raduenz's Avatar
this is how im gona wire my "worklights" on my 08 sportsman for worklight, off, and reverse lights. i think mine is neg side switching from my gearselector switch. mine will be easy since all the wires go into the headlight pod...
gnd side trigger
pos side trigger
Old Mar 18, 2009 | 08:24 AM
  #20
07redrin's Avatar
thanks diagram thanks
Njrider1230
Jul 29, 2023 05:16 AM
house1
Aug 9, 2015 10:49 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
