2005 Yamaha Kodiak 450 rear brake issue
Old Jan 12, 2010 | 02:09 PM
bigjimlackey's Avatar
Default 2005 Yamaha Kodiak 450 rear brake issue
Well, I bought a used 05 kodiak and when I bought it, the rear brake did not work. The brake pad was completely worn out. I replaced them and still the brakes do not work.
When I push down on either the left hand brake (for the rear) or the foot brake, it is like there is no pressure and absolutely no brake. I am 99% sure I put the pads on correctly. I think it is some other issue.
Anyone have any ideas on what I should be looking for or what I could check myself???????
I am no machanic, but I did figure out the pads. Help please.....
Awesome site by the way, great resources.
Old Jan 13, 2010 | 09:05 AM
Dande's Avatar
While I'm not familiar with the Yamaha line, most problems like that sound like either there's a frozen brake actuator or air in the line. Good Luck
Old Apr 14, 2010 | 07:16 PM
truth2ak's Avatar
Default master cylinder
Did you bleed the brakes after you replaced the pads, and check your brake fluid level?
Old Apr 19, 2010 | 07:11 AM
CraZySteve's Avatar
What he said /\
In the future if you have specific questions - IE yamaha kodiak - you are better off asking in the Yamaha section
Old Apr 30, 2010 | 07:39 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
If the machine has been sitting for a while, it could be low on fluid, and air ini teh system is quite common. Also, it may be a good time to just flush the whole system anyway. Moisture gets into them and you should do this every couple years or so anyway. I make it a point when I put my "Summer" machines away, I always change the oil, and brake fluid just to be sure, and then it is ready to go when Spring comes. My year round machines get regular servicing as the seasons change. Spring and Fall depending on how much work I have put them through. Never burned through brakes though. I suspect you might have something going on with the system as a whole.
AK47KID
Jul 23, 2015 09:21 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
MrElussive
Nov 19, 2000 01:51 AM
MrElussive
Oct 26, 2000 02:30 PM
