St.Joe riders
Old Feb 20, 2006 | 11:01 PM
  #71
Gillam450R's Avatar
Default St.Joe riders
stock head nuttin done to it,i will try 200 and see what happens will i have to change my needle or anyhtign what the hell does it mean when it say us ike 4th clip or 5th clip somethign to do wit jets or carb or somehtign
Old Feb 21, 2006 | 12:00 AM
  #72
macanic's Avatar
if your needle is adjustable (which it should be) you have a clip on the needle
It has slots above and below it....Most of the time you should start in the middle....
Just remember your needle adjustment is for mid throttle....
Try 45 pilot and 195 main keep your needle in stock postion...
That should be decent for all around ....winter and summer
Old Feb 21, 2006 | 12:31 AM
  #73
RDZ350's Avatar
Most needles I've dealt with have 5 or 6 notches for the clip to possibly go.Let's say the clip is in the middle slot,and you raise the clip up one notch.With raising the clip this lowers the needle into the main jet.Thus making the mid range a little leaner.Lowering it will possibly help to run a larger main jet.If you try to run with the clip too low or the same as saying the needle too high with a big jet,then the motor gets too much fuel too quick and floods it out.This is just how I see it.Hope this helps.
Old Feb 21, 2006 | 06:36 PM
  #74
Gillam450R's Avatar
i called HFM and told the what i had done to it to find what size jet and there like we don tknow try a 180 and do a plug check so i did the plug check and its perfect!! i just dont see how im runnin a 185 and some guys wit the same bikes run 205 jet wit same mods, any one know what i would have to do to my bike to make it run like a 205 -215 what other mods could i do to make it run a higher jet wit lots of power gain besides boring
Old Feb 21, 2006 | 10:30 PM
  #75
RDZ350's Avatar
Why not try a larger jet(200-205) and see what happens?You might have to raise the clip a notch if you go with alot larger jet but just try the larger jet first.If it don't work,just put it back where it was.Try it,you might like it.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 22, 2006 | 08:09 PM
  #76
Gillam450R's Avatar
well i was gonna get a 200 but hwne i was pickin it up a guy told me that it was gonna get tomuch fuel so i wnt wit a 190 and its runs better but i htink img onna go wit a 195 and that should be just about perfect
Old Feb 22, 2006 | 10:26 PM
  #77
RDZ350's Avatar
I might be wrong,but I want to jet mine too rich at first just so I don't keep wondering if I can go richer.Then I can slowly start jetting down.
Old Feb 22, 2006 | 10:28 PM
  #78
RDZ350's Avatar
Hey guys,I got to change my name on planetsand to race-a-holic.
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
black_thunder
Sep 20, 2015 10:21 PM
awer1968
Sep 8, 2015 11:02 AM
