Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Tire rubbing tie rod
Old Dec 24, 2007 | 05:43 PM
rc3's Avatar
rc3
Default Tire rubbing tie rod
Has anyone had this problem. Me and my dad both have rhino's and are running 26" mud lites. Our Front tire are rubbing the tie rods, mine is the drivers side and his is the passenger side!
Ray
Old Dec 25, 2007 | 02:01 PM
DesertViper's Avatar
If only one side rubs I would be suspicious that you have a bent spindle. If both sides rub you are using the stock wheels that may have too much backspacing for the oversized tires.
DV
Old Dec 25, 2007 | 02:46 PM
rc3's Avatar
rc3
I am using my stock wheels, both sides are close but only one rubs, my dad is running afteremarket wheels with a different offset!
Old Dec 26, 2007 | 05:19 PM
Rudedog's Avatar
I too would agree it's probably a bent spindle... I bent mine, but the opposite way.. Toe'd out like 3-4 inches... the make aftermarket spindles, but their pricey, like $899.00..
Rude Dog
Old Dec 26, 2007 | 09:59 PM
Must ... keep ... Rhino ... on ... ground. They break and bend steering components like nobodys business otherwise.
Old Jan 3, 2008 | 10:19 PM
Rhinofrank's Avatar
I had that problem. There is a slight difference in the offset of the front and rear rims(stock ones). It can be measured but is easily overlooked. Swap the front with rear on the side that rubs. Rhinofrank.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
