Raptor hard to start
Old May 16, 2003 | 01:15 AM
abennett's Avatar
Default Raptor hard to start
Hi
What would cause a Raptor to be hard to start? I have to crank it for upto 3 minutes to get it started when its cold. Its even hard to start when it hot. I have to hold the throttle 1/4th down. It never starts when the choke is used.
Thanks
Old May 16, 2003 | 01:59 AM
Mr45auto's Avatar
Dont touch the throttle when trying to start. Also if your idle speed screw is adjusted too high it will be hard to start.
Old May 16, 2003 | 02:08 AM
RoostItUp's Avatar
Done any mods to it? If so your prolly running lean on the bottom end which would make it hard to start. Try richening up the air screw by turning it out about 3 full turns.
Old May 16, 2003 | 06:13 AM
Ward660R's Avatar
How many hours do you have on it, roughly? A badly worn cam chain will cause hard starting, but it will turn over VERY slow if it even turns over. Makes it seem like you have too much compression or something.
Old May 16, 2003 | 09:18 AM
raptor8's Avatar
sounds way lean for some reason. look for a vacuum leak. have you ever adjusted yer valves? that seems to be the penicillin of the raptor...low tire = adjust the valves. boots on the carbs and intake? crud in the fuel flow between the tank and the carbs? start at the spark plug. put a new one in. see how it starts. no change? then start at the gas cap and follow the trail down. simple. good luck! [img]i/expressions/face-icon-small-tongue.gif[/img]
Old May 16, 2003 | 11:18 AM
Ward660R's Avatar
Not saying its wrong, but if it was lean wouldn't the choke help it to start?
Old May 16, 2003 | 09:41 PM
raptor8's Avatar
yeah thats really weird too. i wonder if it idles OK...partialyy stuck choke maybe?
Old May 16, 2003 | 10:23 PM
abennett's Avatar
Hi
Thanks for all these replies! The Raptor idles well after it warms up. The valves have been adjusted recently. Where is the air screw so I can try to richen it up? Its a real pain trying to start this thing, it will just about kill a battery.
Thanks
MikeyBoyesq
Nov 27, 2020 02:44 PM
jayking232003
Jul 6, 2015 02:41 PM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
dunc_n
Aug 26, 1999 09:32 PM
