Pro Flow Adapter?
Old May 19, 2003 | 01:53 PM
slappie's Avatar
Default Pro Flow Adapter?
Wsh,
Thanks for the clarification man. I never tried to force it on there, just didn't want to jack anything up.
Fizzak,
Make sure you cut and smooth all the areas of the inside of the airbox that come into contact with the K&N. I didn't do this at first and had to buy a new K&N and outerwear because the rubbing caused a hole in my outerwear and filter. It even wore thru the metal cage on the K&N filter! I thought I had it smooth enough but I guess not!
Even after I did smooth out all the edges, there was still some chafing so be careful. I'd advise to figure out where it contacts the airbox and then put a small piece of electrical tape over the outerwear at that point as an extra measure of safety.
Old May 19, 2003 | 11:07 PM
wshrdskin's Avatar
Originally posted by: slappie
Fizzak,
Same here.
A dremmel tool would work good. Anyway you can, get rid of all the flanges on the lid (if you use it) and the sides. Anything that is close to contacting the filter.
franklyme
Oct 21, 2016 07:18 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
1ArmBandit
Aug 6, 2015 06:37 PM
ghost civic
Jul 19, 2015 10:13 AM
