My Engine Blew :-(
#112
I believe the stock raptor rod is steel, only engines I have seen aluminum rods in are dragster engines that get rebuilt quite often. I am guessing BigBubba is running the steel Carillo rod now.
BigBubba- Did you have to get new cases? What all new parts did you have to buy? Glad to hear you got it running again.
#113
OH wow! Uhh I'm running the Carillo rod now but in terms of what I had to replace...ugh this is huge. Rod, piston, valves, sleeve, both cases, clutch cover, and the whole transmission. I also replaced parts with heavy duty ones and those are starter one-way and the clutch. I almost had to replace the crank too cause it was pretty beat up but not enough to replace so I just got it balance and cleaned up. Other than that I think thats it.
#114
KimSJoh
14
Jul 18, 2015 07:20 PM
