My Engine Blew :-(
#21
Originally posted by: Ridley
In my experience, lean motors make more HP on top, but not for long. So far in my reading, I haven't seen any rod failures from people running bigger jets. like 170/175 or bigger. I think they may be onto something there. When you jet for absolute max HP you can guarantee a lean condition every single time, you gotta back it off a little to be safe, at least with my experience. Didn't you just pay alot of money to have that thing jetted?
#25
I may have missed this earilier but did your 01 trans fail causing the gear swap? This lockup has been a common occurance with the rod failures. I'm thinking if the trans goes and the case is split just replace the rod then. You're making me sweat the 686 12:1 stage 2. Although my jetting is 195/200 presently as 185/190 left me a damned white plug.
#28
sorry to hear that bigbubba but i am sure you will find a way to get it running again.i was considering a cam ,valves ,and port work but i think i may just have to be content with the mods i have because rod failure sounds pretty scary.does anyone have any idea at what point horsepower wise that these rods start going or is it just a bad luck thing?i was very seriously considering a major rebuild in a couple of years along with a big jump in horsepower but after hearing so many bad luck stories i dont know.well good luck bigbubba on the rebuild hopefully we will see you on the dunes sometime soon.
#29
rudyraptor: Yes, I am.
duneittillyoudie: You've seen me at south jetty a couple times, I was driving the blue lifted chev s-10 with fenderflares and riding the blue rappy in my gallery. I know you were parked right behind me a couple weeks ago cause sandman430 told me. Do you remember seeing me racing on the face or comp?
#30
no i didnt see you but if i had i would have had a few questions for you and i sure would have liked to have had a chance to at least make a good effort against your quad.i am pretty sure i know what the outcome would be but i am always ready to give it my best.maybe when you get your raptor back together we can try a run or two just dont make me sound too bad if you mention it on here.actually i am very pleased with the performance i get with the few mods i have and just last week i finally took my air box lid off and upped my mains to 175-180 and that made a huge difference.i am having some problems with my clutch slipping so i have to sort that out although it may just be adjustment.well maybe we will get a chance to meet up sometime at florence and see just how bad you can whoop me and once again good luck on the rebuild.
