Reverse my front wheels?
Old May 23, 2003 | 05:36 PM
Hayseed's Avatar
Default Reverse my front wheels?
Old May 23, 2003 | 05:39 PM
Hayseed's Avatar
Does it put as much stress on hubs, bearings, and a arms when you reverse your front wheels as opposed to wheel extenders? I know it's not the best thing to do but does it work ok?
Old May 23, 2003 | 06:08 PM
Vforcer's Avatar
Biggest stress is on the tie rods.
Old May 23, 2003 | 06:17 PM
atvrider82's Avatar
not worth it, just buy the extenders cause if you break the tie rods you'll be putting the same (prolly more) money into it to fix it.
Old May 23, 2003 | 06:31 PM
polarisisthebest's Avatar
You will also bottom out your shocks alot easier if you flip your rims.
Old May 23, 2003 | 07:52 PM
BlueLeader's Avatar
wheel extenders and flipped rims or different offset rims all cause the same increased stress on components. If you flip your rims put a new valve stem on the outside so you don't have to remove your tire/rim to add air. It's a pain.
Old May 23, 2003 | 09:25 PM
Hayseed's Avatar
Thanks to all.
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
Scottma518
Jul 10, 2015 12:42 AM
jettman
Jul 6, 2015 12:16 PM
