Banshee - Big jet => Broke Piston
I got pro-circuit pipes and K&N (no srokel) and jetted it to 340s on an otherwise stock motor.
I was screaming pretty good til I broke a piston on the rear near the holes. The dang plugs
looked really good but I am guessing thats too much jet for a stock bore/pistons.
Anyway how the h3ll do I extract pieces of piston from the crankcase? I've hear rumor that
if you fill the empty the crankcase of oil and fill with gas, the metal will float to the top, but
I dunno about piston chunks. hehe Anyone got ideas? I dont want to split the cases if I
can help it.
Regards,
-map
The piston skirts are known for cracking in front of the intake ports or braking in your case. I would plit the cases no matter what and remove all the pieces out of the crank area. Since you have the cases split, port match the upper case to your jugs intake ports for more intake flow.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
