Griz Tire Question
Old May 29, 2003 | 01:46 AM
Joel123's Avatar
Default Griz Tire Question
Hi,
I would like to replace the stock Dunlops that came on my 2003 Grizz 660, I would appreciate any suggestions in what others have put on there machine. I ride a mix of Hard trail and some mud.
Thanks for any info
Joel
2003 Yamaha 660Grizz LE
1999 Polaris Magnum 500
Old May 29, 2003 | 09:12 PM
yamaguy's Avatar
I just replaced the tires on my Grizz with ITP 589 M/S 26-12-12 rear and 26-9-12 front and absolutely love them. They pull through mud much better. As far as trail riding goes I didn't notice any improvement, but that's not what they're made for either. 589's are a mud tire, so if you do alot of trail riding you may want to consider something a little less aggressive, but if you do alot of mud riding, then I highly recommend them. Hope this helps. You might try 589 M/T (mud/trail) as opposed to M/S (mud/snow)
Old May 30, 2003 | 01:23 AM
Joel123's Avatar
Thanks for the reply, I am thinking that a straight mud tire might be a bit much? but I have sure noticed that the stock dunlops don't like the mud. I was wondering what out there was a good combination tire, and one that works well on the Grizz.
Thanks again
Joel
Old May 30, 2003 | 10:19 AM
Andy Bassham's Avatar
I've got a set of 27" Claws that use at times, but I'm figuring on replacing my stockers eventually with something. I like the looks of the ITP radials, but I'll probably end up with Bear Claws. They are a good all around tire, and don't weigh a whole lot in 25". Also looked at Sur Tracs and All Tracs in that size too.
If I didn't have the Claws at all, and just had one set of tires on stock rims, I would probably have 26-12 Sur Trac rears and 26-10 Spider Trac fronts.
Old May 30, 2003 | 05:28 PM
BADBEARnoSportsman's Avatar
joel, you want the goodyear rawhide grips, i put them on my grizz and they are great. they come stock on sportsman 700, check them out, you will love them.
Old May 31, 2003 | 03:03 AM
hondaracer305's Avatar
ya, id get itp
Old Jun 2, 2003 | 02:09 PM
zanman's Avatar
i have and highly recomend the itp mud lites,i put a pair onthe rear of my sons 2wd suzuki 250 and they work excellent in the mud and on the trail.
Z
Old Jun 3, 2003 | 01:27 AM
Joel123's Avatar
Thanks guys for all your suggestions, lots of great tires our there, I guess one has to flip a coin and go with it.
Joel
Old Jun 3, 2003 | 01:30 AM
660x2's Avatar
i'd highly recommend the titan 589 mt's from nebraskatire.com. they are blems, but they are only 35 bucks a tire!!! that's where i got mine. no problems with them other than they grind the name off the sidewall.
Old Jun 3, 2003 | 12:56 PM
Joel123's Avatar
Thanks for the Tip, I'll look into that one
Joel
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
