how hard is it to jet a raptor??
im not modifying anything...stock filter, stock box, stock head pipes. The only thing i am changing over stock is the slip on yoshi. Should i just go up one size from what stock is? If i can almost leave it without jetting, then one size up should be more than enough no? thanks
#16
If you are just installing a slip on you will be fine with the stock jets. When you get an after market filter with the pipe combo it will be a good idea to rejet.
It's a pain in the booty to change jets on a raptor. If and when you get an after market filter I would suggest getting a jet kit. It will simplify your dial in and make troubleshooting a lot easier.
#17
#18
warrior86, I installed a Sparks slipon on my Raptor when I first got it and the stock jetting did not work with it so I put the dynojet jet kit in and this cured everything and the bike performed very well for a slipon. I'm not telling you to buy the kit but this was my experience with a slipon and the kit is what fixed mine. You will be real lucky if the stock jetting works because the slipon will flow more air and the bike will need more fuel. You can get the mikuni jets individually and rejet it also but I did like the better throttle responce from the dynojet kit. Good luck, SLIM
#19
Jetting Instructions
Good Luck if you choose to do it yourself. It can be a pain, but it's nice to be able to do it yourself.
That's what pushed me into doing my own work.............one to many screwins' [img]i/expressions/face-icon-small-shocked.gif[/img]
