Blaster
Old Jun 13, 2003 | 01:54 PM
Dick123's Avatar
Default Blaster
Can someone help me with my blaster. I have figured out that they are the cheapest, most junk quad that is out there. It started running rough, (just not real responsive), and then stopped running. So, I checked the spark to find none. I went through the mannual, and did everything it said for no spark problems. Nothing helped. I checked all of the connections, and I didnt find any that were loose, but it started to spark again. I put it back together, and it ran GREAT. (Better than it had for a LONG LONG time) Then, I was ridin, and it just died. I was getting POed by now, and I pulled it home. I found that the woodruf key was sheered in 3 pieces. (What could have caused this?) I got another one, and put it in, and made sure the rotor was tight. I started it up, and it ran, but it was really crappy. I hauled as fast as it would go, (which wasnt fast) and did a one wheel endo, and then went through the yard and jumped off and it hit a tree. LOL!!!! I left it set, hoping that someone would steal it. I HAVE TO get rid of it and get something worth having. Does anyone have any hints on what to check. (It is not the CDI, control unit, or the other component under the hood I used a meter to check the coils, and they were good too)
Old Jun 13, 2003 | 02:19 PM
BLASTERDEVIL2's Avatar
Default Blaster
your stator could be bad. i have never check one or no how to check one. but someone on here might. try pm'ing toomeyblaster. he might have messed with one before. but it sure sounds like the stator. check the connections in there.
Default Blaster
also check where it goes through the case and make sure there is no open wires that are shorting.
Old Jun 13, 2003 | 02:59 PM
85Rrider's Avatar
Default Blaster
How much do you want for it?
Old Jun 14, 2003 | 05:51 PM
Dick123's Avatar
Default Blaster
Well, again, it is running aight. Puzzled. But I am going to sell it anyways. $1500
big_bad_jon2006@yahoo.com
Indiana
Old Jun 14, 2003 | 06:19 PM
dirtrider078's Avatar
Default Blaster
what year is it?
Old Jun 14, 2003 | 09:09 PM
hondaracer305's Avatar
Default Blaster
On my Banshee, the stator is under the stator cover on the left side.
Old Jun 14, 2003 | 11:13 PM
Dick123's Avatar
Default Blaster
It is a '99. I checked the stator. It is in the specks of the manual. I got it running right now. I dont know how, but it just popped out of it.
Old Jul 26, 2003 | 10:09 PM
supersampson's Avatar
Default Blaster
Dick... you are really a dick, and definatley not a mechanic...
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
