adding teeth to rear sprocket vs.dropping teeth on front
Old Jun 15, 2003 | 05:53 PM
blinddog's Avatar
Default adding teeth to rear sprocket vs.dropping teeth on front
which technique is better and why?
i have an 01 raptor and wanted better dune hill climbing speed.which way is best?
Old Jun 15, 2003 | 06:34 PM
NotuRaptor2's Avatar
You lose less power by going higher in the rear. It robs some power with a smaller front sprocket due to the tighter radius. Just make sure your skidplate will handle a 43 tooth or you will have to shim it. In the trails though, it isn't much of an option to leave the front at a 13 tooth since 12/42 seems to be the right combination. This would be the equivalent of 13/45. You would lose a lot of ground clearance with the combination plus need a longer chain.
/NotuRaptor
WilliamBos
Jul 13, 2015 02:11 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
