Rappy Oversized Valves....
Dumont,
It ALL depends on whatyou want man!
If you want to challenge SPARKS to a hill drag, then GO BIG on your Valves,carbs,cams,and BORE size(and alot of NITRO[img]i/expressions/face-icon-small-wink.gif[/img])
But if you want a SOLID 60 hp machine, that is competitive and you can still DUNE all day with out worry of over heating, or breaking down then go with a good 686 and call it good. you wont need larger valves, or larger carbs.
P.S. the difference between Competitive and Stupid fast is about $3000 so...... you have a big decision to make.[img]i/expressions/face-icon-small-confused.gif[/img]
Bigger.
Bigger.
#15
As of right now I have zero plans of stroking it, i might go with a larger sleeve based on advise. Ill get the head ported and polished and get the oversized valves, how much are those titanium valves? and where can I get them. How much are oversized stainless steel???? When I get my head ported and polished should i send the valves as well to get them seated and to match them up with the head as well???? Will it be alot of work making sure i dont put a valve through the gosh darn piston?
