Raptor pipe probs.
Old Jun 25, 2003 | 08:57 PM
loneoakracing's Avatar
Default Raptor pipe probs.
I just reinstalled my yoshi pipe. now i have exhaust coming from around one of the head pipes. I took the pipe off twice to make sure the pipes are not bound up. Could the metal gasket be worped or warn out causing my problem? also the motor has a real bad backfire when letting off of the gas now and occasonally sputters could this be caused by the pipes not being sealed?
P.S. the original reason i took the pipes off was because the exhaust studs broke off (2 of 4) because i torqued them down to much. i was told this was the reason be the yamaha mechanic.
any help would be greatly appreciated.
Old Jun 25, 2003 | 09:19 PM
RacinJason's Avatar
It sounds like an exhaust leak for sure...I'd replace your gaskets and try again
And Yamaha in thier infinite stupidity used exhaust studs the same size as my XR50 so they won't take very much torque
Old Jun 25, 2003 | 09:47 PM
HappaRap's Avatar
Lazy Boy Rider!
When I installed my Yoshimura, it was a real bear to get things lined up, I torqued per specs in the manual and luckly everything went together without exhaust leaks. Took alot of swearing but in the end it was surely worth it.
I thought those studs should have been tighter but so far, no problems. As RAPTORJAY said replace the gaskets and give her another try.
Good Luck
Old Jun 25, 2003 | 09:53 PM
warrior007's Avatar
My friends yoshi broke the studs too, I replaced em with 8mm year 2000 grizzly studs (had to drill theyoshi header flanges too). I think the metal on the yoshi expands more for some reason, I have heard of more broken studs with yoshi and none with other headers.
Old Jul 6, 2003 | 02:24 AM
HappaRap's Avatar
Lazy Boy Rider!
Well now my exhaust header stud snapped. Mine was the outside, brake side.
Old Jul 9, 2003 | 05:19 PM
BigScary's Avatar
if you think Yoshi is bad..........you'd better not get a dmc for the rappy!!!
My friend had the dmc on his rappy for a week and it broke both studs of one of the headers
Old Jul 9, 2003 | 05:22 PM
CTRaptor's Avatar
My flanges on my CT are bent.. overtightened them and I saw that there was a whole lot of peeps with broken studs so I looked but none. Guess Im lucky.
Old Jul 9, 2003 | 05:45 PM
WallStreet's Avatar
Mine haven't broke yet. Maybe I should get Sparks. Thoughts?
Street
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
black_thunder
Sep 22, 2015 07:59 PM
greg86hd
Sep 16, 2015 12:32 AM
Alex Rodak
Sep 12, 2015 09:39 AM
