New Grizzly
Old Jun 27, 2003 | 08:23 PM
mrkleen's Avatar
Default New Grizzly
I have a 03 grizzly and have only got to ride about 3 times, today after work went down to a river bottom pretty close and after riding for a while the belt seemed to slip. I haven't been in mud or water can heat make it slip? It would slip when it started pulling good like out on the road. It will still pull a wheelie but when you get out and start getting in it thats when it happens. I have never owned anything but a honda till now I really like my grizzly so far. Any suggestions?
Old Jun 27, 2003 | 08:47 PM
mich660griz's Avatar
Default New Grizzly
the belt should never slip on the griz, in any conditions. if yours did or does slip, it has gotten wet, got mud/gunk in it, or is wayyy to long between cleanings. chances are it has gotten wet. maybe it is leaking on the rubber boots? this has happened to others.
i would pull the clutch, mic the belt, and check it for glazing. grease up the weights, and i am sure it will be fine. i can stand mine up without the belt slipping, and it never should. you might have glazed it by now though.
good luck.
Old Jun 27, 2003 | 09:21 PM
mrkleen's Avatar
Default New Grizzly
It only has 140 miles on it I was on a gravel road when this happened and I have been in any mud today. We took a big ride on Sat night and got kinda muddy never put in 4wd
Old Jun 27, 2003 | 10:11 PM
mrkleen's Avatar
Default New Grizzly
also what gear should I run in when trail riding Low or High
Old Jun 28, 2003 | 06:31 PM
OregonYamaha's Avatar
Default New Grizzly
I always use High on mine when riding just trail riding. If I get to a really muddy section I will use 4 in high and if that still does not work... I go for 4 LOW baby and use all the power that she has got... WOOHOOOOOOOOOOo... Just hold on!
-David
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
