K&N sucks what filter?
Old May 15, 2000 | 12:42 PM
HoundDog06's Avatar
[blue]I use a k&n on my warrior w/outerwear. I ride the riverbed of the south canadian, it doesn't get much dustier than that, and my k&n has worked great. You might look into the possibility that it is your airbox, not your filter, that is restricting you.[/blue]
Old May 17, 2000 | 08:55 PM
MonsterGrizzly's Avatar
The K&N Airfilter has shown it's reliability to me and nobody can change that.
Old May 18, 2000 | 01:57 AM
BK.FORTUNE's Avatar
I agree with all the other K&N filter users. I've had a K&N filter on my Banshee with an outwear since I bought it. Works great in the dusty conditions I ride in.
'98 Banshee, FMF Fatty's w/Power Core II's,Pro Design Coolhead/21cc domes,Works Triple rate fronts w/out rezzy, Pure Sport Bandit XC's on Douglas .190's,Pro Design Pro Flo Filter Adapter w/K&N,Graydon Front Bumper.
Old May 18, 2000 | 11:23 AM
DunePilot858's Avatar
I think that you over oiled the K&N. When you did the plug check you saw that it was rich. Let the filter sit on an angle for a day and reinstall it and see if that helps.
Old May 18, 2000 | 01:40 PM
  #15
NYBanshee96's Avatar
I just replaced my foam filter with a K&N and all I have to say is that It works great in every way possible
NYbanshee
96 Banshee
Old May 18, 2000 | 02:09 PM
  #16
Quarryboy's Avatar
Im not saying k&ns are bad(well i am)but it didnt work for me.Did you guys rejet? If so will going down a size on the main jet make my blaster slower?
ps anybody that has k&n on there blasters that i know says it improves throttle response but thats it and they have to clean them a lot more often
Old May 18, 2000 | 04:49 PM
  #17
quadcrazy's Avatar
I have a K&N filter on my warrior with no holes in my airbox, no jetting. It works great for me.
An earlier poster had said that you might have put to much oil on your filter. Well that gentlemen is absolutely correct by saying that.
Also if you want a little extra protection.
Add a thin coat of Bel-Ray waterproof grease at the front of the filter before inserting it in your airbox. It acts like a gasket between your air box and filter. Trust me this works. My family has been racing Motocross since the early 80's.
Old May 19, 2000 | 08:39 AM
  #18
musclford's Avatar
Not being facesious, but if you have to clean them more often, that normally means that they are filtering better. Whereas the others are letting the microscopic pass through. I too have used K&N's, and they work great.
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
DM2015
Sep 7, 2015 10:36 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
