Banshee rebuild?
Old Jul 1, 2003 | 02:22 PM
BIG_RED's Avatar
Default Banshee rebuild?
My banshee has just started making a noise from the engine that sounds like there is a tiny ball bearing bouncing around in there. At idle it only taps a couple of times every few seconds but when I hit the throttle it taps a lot. It is also noticable when decelerating. I don't know much about the tell tale signs of a rebuild on a two stroke engine but this definately is something I don't want to ignore. If anyone could please tell me what might be wrong, I would greatly appreciate it because I would rather fix it now instead of waiting until something terrible happens. Thank you very much.
Old Jul 1, 2003 | 02:43 PM
hondaracer305's Avatar
It comes natural if you have a pipe like fmf because my friends does that exact same thing.otherwise i dont know.
Old Jul 1, 2003 | 04:47 PM
Rudedog's Avatar
Are you sure it's the motor???? Could it possibly be the kick-starter??? The kick starters usually loosen up and start rattling after a while. Have someone hold it while you rap the throttle up a few times and see if it quits ....
Rude Dog
Old Jul 2, 2003 | 01:45 AM
Ernie660R's Avatar
I think it is your clutch basket moving around on a loose bushing. But it could also be a crank or wrist pin needle bearing.
Old Jul 2, 2003 | 12:17 PM
BIG_RED's Avatar
The sound is definately from the engine, and it isn't the kickstarter. I myself think it is probably a wrist pin bearing, but I will have to check into the clutch basket bushing thing. Anybody else have any suggestions?
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
