Rejeten my Warrior ???????
Old Jul 7, 2003 | 01:02 PM
Warrior453's Avatar
Default Rejeten my Warrior ???????
how do i rejet my 01' warrior i see where the carb is and there isnt a hose to disconnect from the engine to the carb theres a connecter what do i do? please help me
Old Jul 7, 2003 | 02:20 PM
Warrior453's Avatar
Old Jul 7, 2003 | 02:45 PM
HILLWARRIOR's Avatar
this is very easy to do......first take off the snorkel from the air box to the carb and get it out of the way.turn off the gas also.now the carb is connected to a rubber boot with two bolts (this boot is also connected to the cylinder)just unscrew the nuts on the that hold the carb onto the boot.now the throttle cable does not need to come off just pull the carb off the boot.now flip the carb up side down(under side of the carb is the bowl)the bowl is held on by 4 screws if your lucky you can get them with a screw driver but if not use a locking needle nose pliers on them.once you get the bowl off you will see two floots and in the middle of the floats is your main jet.unscrew it and put in another one.so are you putting a new needle in to?? let me know if i was any help.................GOOD LUCK!!!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
