Who does the best 4 stroke porting?
#21
#22
That is probably the way I should have said it. I agree with airraptor; if you go with someone who does only porting it is most likely they will be willing to spend a little more time doing and touching up on the little things that could make a big difference. I also agree that all the companys mentioned can do a good job. Slim
#23
Thank's slim for being a stand up kind of guy,that does not happen too offen here. The only thing I can say that no one has said is simply ask how much the head flow's for you atv stock and how much more will it flow when you get it back. If they cant tell you that then stay away from them.
#25
I appreciate you excepting the apology and again it was not meant to offend anyone it just came across a little different than I intended so I'll be a little more careful with the way I put things from now on and yes I am familiar with some of your work and I know it is good work. You have done some good work for a friend of mine Freddie Sanford. Thanks Slim
exmotocrosser
09-13-2019 06:12 AM
BYC
09-25-2015 02:10 PM
Quadzilla Heritage
09-25-2015 01:39 PM
