glowing header?
Old Jul 12, 2003 | 03:40 AM
BigScary's Avatar
Default glowing header?
after gettin my rappy hot........the header glows BRIGHT red......I mean you can see it in the middle of the day..........one of my friends told me that, that means that it is too lean?.......is this true?
Old Jul 12, 2003 | 03:53 AM
SLIM660's Avatar
It could be lean. Check your plug and see what color it has to it; If it is white gray lookig it is lean. Another thing you can do is look at the end of your pipe and see if it has a white gray looking powder like substance on it; this can be another sign of being lean. Another sign of being real lean is if you gas it and it seems to quit puilling early in the gears it could be lean. To do a proper plug check put a new plug in ride it around for a few minutes and make a wide open pass through 4th gear and shut the bike off at wide open throttle in 4th; coast to a stop then pull your plug out and check it. Slim
Old Jul 14, 2003 | 10:53 AM
BigScary's Avatar
ok I will have to try that plug test.......but the end of my pipe has Black Sutt on it.......
Old Jul 14, 2003 | 01:32 PM
HoundDog06's Avatar
Check your valves too. Glowing pipes can be a sign of maladjusted valves. If the exhaust valves are too tight you could be sending combustion through your headers.
~HoundDog
Bigtwin700
Sep 9, 2015 09:32 AM
Stillonit
Aug 5, 2015 07:46 PM
zach1106
Jul 31, 2015 01:55 AM
slimedog
Jan 27, 2000 08:38 PM
