Sprocket wont fit on cam!!
Did you remove the cam tensioner ***'y???
You should have a plug on the the side of your cylinder near the cam chain. You will need to remove it to give you enough slack in the chain to install the gear in the chain then the gear on the cam. Be careful tighening up the cam bolts...........that ***'y is a little delicate.
You don't need a hammer to do the install.
Good Luck
Good Luck
I did some looking for you.........it's item #11
1998 Warrior Cam Chain ***'y
Remove this assembly and it will go right together.
GregV
GregV
