blaster help quick
Old Jul 12, 2003 | 02:39 PM
dirtrider078's Avatar
Default blaster help quick
ok this is my prob. i got a toomey a few weeks ago and i jetted down to a 290 and it is still falling on its face. i got a compression check and it is 100 [img]i/expressions/face-icon-small-sad.gif[/img] how low can it go befor you blow your motor. should i put a new top end in?? also what type of top end kit should i get?? wiesco or vito??
Old Jul 12, 2003 | 04:50 PM
Peltrax's Avatar
Was it acting the same way before you put the pipe on...Its definitly time for a rebuild.....i would get the vitos it has more power.......HOw did you set the air box up....i run a 300 in mine with no airlid and im at sea level and it runs great.......
Old Jul 13, 2003 | 03:25 AM
raptor8's Avatar
I run a 310 at 4000' no lid and it runs great. did you move the needle up one per instructions? that is, move the clip down one.
Old Jul 16, 2003 | 10:39 PM
kaveman's Avatar
if i am not mistaken, i am running a 210 in my blaster (28 mm) carb while u guys are running 310's etc..can someone explain why my jet is so much smaller?
Old Jul 16, 2003 | 10:46 PM
dragracer789's Avatar
every motor is diffrent! Thats why, plus temp. and humidity has a roll in jetting.
Old Jul 16, 2003 | 10:52 PM
Peltrax's Avatar
Its probably becuz you have a bigger carb..
Old Jul 17, 2003 | 04:01 PM
JakeThreeight's Avatar
100 pounds of compression is not very good if i were you bore over to the next size and put in a vitos piston I've had vitos in mine for awhile and they work great.
jake
flyin-lowe
Dec 1, 2017 03:18 AM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Rooky
Sep 9, 2015 03:16 AM
