some blaster help...please?
Old Jul 14, 2003 | 06:57 PM
kaveman's Avatar
Default some blaster help...please?
i have a question...i want to know how fast my blaster will go when i get my 240 complete cylinder kit. I have a bill's pipe, delta v-force reed valve, vito's degree key, 28mm carb, k&n pod filter, 240 complete cylinder kit, oil injection block off (not really relevant to my question) and 18 in ITP holeshot tires. Now if i didn't forget anything, i am wondering if someone can estimate how fast my blaster will go if i put a 39 tooth sprocket on the rear and a 15 tooth sprocket on the front. Oh and i weigh 130 lbs...also would i be correct or at least nearly correct in saying that it produces around 40 hp, b/c vito's advertises the 240 kit at 32hp but working in junction what would u guess the hp would be at. thanks for the help
Old Jul 14, 2003 | 07:01 PM
BLASTERDEVIL2's Avatar
hp sounds about right and your top speed should be around 72-75 due to the fact that your tires are only 18's. maybe if you put 20's you could get over 80. but with that high of gearing if going to take awhile to get there.
Old Jul 14, 2003 | 10:35 PM
kaveman's Avatar
well i figured by going up to the 240 kit i would have enough power to still be able to accelerate quickly cuz right now i am running it with the stock size and am beating 400ex's off the line, anymore input and guesses att top speed..please?!
Old Jul 14, 2003 | 10:41 PM
Knutz99's Avatar
If you want to know your exact top speed, a Trail Tech speedometer is about $75.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
