raptor reverse light problems help!
Old Jul 16, 2003 | 03:03 PM
zwillraptor's Avatar
Default raptor reverse light problems help!
I have had my raptor at yamaha three times now because the reverse light comes on after the atv gets warmed up and i am running down the road. The light comes on and the bike shuts down. When I pull the clutch in and let it back out the light goes off and the bike runs again. But within a few seconds it does it again. It is really bad when i am at top speed.
Has anyone else had this problem?
Thanks
Old Jul 16, 2003 | 03:14 PM
WallStreet's Avatar
Sounds like an eletrical problem to me.
Street
Old Jul 16, 2003 | 03:27 PM
warrior007's Avatar
your raptor must be a 2002 or newer.
They have a limiter for when you are in reverse. Problem is if anything happens to the wire from the cdi to the switch down by the sprocket you will get shut down and the limiter engaged in ALL gears - the light will also come on.
I cannot believe they cant fix it.
What you need to do it pull off and clean the wire that snaps onto the reverse switch at the sprocket. Maybe even pinch it a little so it gets good contact. If that doesnt fix it the switch is malfunctioning - if you have a an ohm meter check the pin on the switch to ground - you should have 12 ohms in all gears except reverse. In reverse the switch goes open.
The CDI can see when the switch goes open and triggers the light and limiter. so you have an open somewhere, clean the connector very good.
Old Jul 16, 2003 | 03:38 PM
Yamaha660R's Avatar
Definetly an electrical problem. I would take it back to the dealer and tell them to fix it right this time.
Old Jul 16, 2003 | 10:57 PM
F8LRAPTOR's Avatar
mine done that, and a few people i know had that problem, i took the wire coming off the sensor and hooked it to a ground. the light dont work but i have my nitrous switch there anyway, you should know when its in reverse you really don't need a light
Old Jul 17, 2003 | 10:03 AM
Its a 2001 raptor. I will check out the switch connection.
Thanks for the help!
Old Jul 17, 2003 | 11:34 AM
garyc660R's Avatar
In the winter time....I look at the light as a colorful decoration....spreading a little cheer for the people behind you....which is everyone.
AtvManiac78
Jul 11, 2015 03:20 AM
kodiak450.
Jun 17, 2015 02:22 PM
VascoConroy
Jun 12, 2015 10:30 AM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
