Yoshimura says stock jetting is ok?
Old Jul 17, 2003 | 06:39 PM
QueenQuad's Avatar
Default Yoshimura says stock jetting is ok?
o yeah a motor will run the fastest with the most horsepower when its the leanest
Old Jul 17, 2003 | 06:57 PM
HoundDog06's Avatar
And if your head isn't already swimming with questions like "How lean is too lean?", check out this thread. (Have apirin handy!)
~HoundDog
Old Jul 18, 2003 | 02:39 AM
AustinONeal's Avatar
some one tell me what i need where to get it and how much
ill pick up whatever it needs
Old Jul 18, 2003 | 09:41 AM
BlackWidow's Avatar
Well I wouldn't let black in the exhaust tip bother me too much. If anything, you got a leaner mixture by putting the pipe on.
If it's running good, then I would leave it alone. If your hunger is for more power, then buy a Pro Flow kit with a K/N or foam filter and a jet kit. Take the airbox lid off, get a little filter for the tube that hooks up to your snorkel and jet it according to the directions in the jet kit.
As far as four strokes making the most power, they like being a little on the rich side rather than a two stroke, which likes the mixture a little on the lean side.
Old Jul 18, 2003 | 10:04 AM
  #15
Murph66's Avatar
I don't see much point in putting a pipe on without opening up the airbox also.Do the airbox mods Yoshi recommends by cutting (2) 1 3/4" holes in the lid. You don't need a jet kit. Yoshi recommends 150/155 Mikuni jets. Don't change clip position or anything else. Set your idle fuel screws at 2.5 - 3 turns out. You will like the results. I do
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Bigtwin700
Sep 9, 2015 09:32 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
