Raptor Crankcase breather blowing oil
Old Jul 20, 2003 | 10:56 PM
wshrdskin's Avatar
Default Raptor Crankcase breather blowing oil
Craycraft did the bore and ring gap to their specs. That part is correct. My oil does not turn black right away. It takes some riding before it gets black.
Old Jul 20, 2003 | 11:14 PM
Hayseed's Avatar
Try extending your breather hose and run it up to your handlebars and zip tie it where you can see it when your on your next hill shoot.
Old Jul 20, 2003 | 11:29 PM
ALIENraptor's Avatar
and get a face full of oil hahaha
Old Jul 20, 2003 | 11:50 PM
RaptorOwner's Avatar
If I were you, I would do a compression test and go from there. If you can post it for us.
Thanks
Old Jul 23, 2003 | 12:05 AM
  #15
RaptorRacer1's Avatar
My Raptor only takes just over 2 quarts with an oil and filter change. Maybe 2.1 quarts at max. Are you checking it per the service manual recommended method? Just an idea.
RR1
Old Jul 23, 2003 | 02:25 AM
  #16
ShadyRascal's Avatar
I think a leakdown test is the first thing you do. What is your piston to wall clearance? Some people set them up looser than others like drag motors. Just a thought.
Old Jul 23, 2003 | 03:34 AM
  #17
14mins's Avatar
wshrdskn- Rings will last a long time with good oil and frequent changes. I replaced my rings after 18 months even though they still looked/felt fine.
bmxatv10
Oct 14, 2022 06:23 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
black_thunder
Sep 22, 2015 07:59 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
