VP Ultimate 4 race fuel
  #31
Old 07-25-2003, 04:03 PM
TriRap's Avatar
Default VP Ultimate 4 race fuel
that High of an octane is not needed even with 12: 1 compression. With the additives in ulimate 4 with my 12:1 piston I still do not get detination. Even m1 at $15 a gallon only has 90 octane.
The fuel is more stable and the motor runs cooler.
  #32
Old 07-25-2003, 04:07 PM
SP700RACER's Avatar
Also keep in mind motor octane and research octane are totaly different numbers. 90 motor octane is around 100 research octane.
  #33
Old 07-26-2003, 06:55 PM
XtremeRaptor's Avatar
Will I hurt anything if I run this stuff in my 10.75:1 Raptor? Should I run it mixed with premium pump gas or straight? Any and all info would be greatly appreciated!!!!!!!!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
  #34
Old 07-27-2003, 01:27 PM
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #35
Old 07-27-2003, 01:38 PM
wshrdskin's Avatar
Are you talking of the Ultimate 4? It won't hurt a thing and as many have stated might even give you up to a 6% increase in power. It did not do that for my 11:1 Raptor at least not that I could tell. Run it strait or mixed. It's only 92.2 octane so mixing isn't going to gain you any real octane advantage.
  #36
Old 07-27-2003, 06:44 PM
Hiram's Avatar
Quick note about c12, this fuel has a lower sp gravity which means it will flow more and does cool the engine more, i run it 1 gal c12 to 2 gal. of pump gas and after trying all sorts of float adjustments, modification and finally and most impotantly running a hotter plug my engine is running like a screaming beast on this c12/pump fuel mix. BTW the leaded fuel burns cleaner than the unleaded fuels like VP MS103 which I did think the engine liked as much even with jetting changes and noted the increased exhuast residual.
  #37
Old 07-28-2003, 04:49 PM
TriRap's Avatar
rejet to use straight ultimate 4. you will have no problems.
  #38
Old 07-28-2003, 10:23 PM
Zhvonte's Avatar
I run aviation fuel.... its only two buck and some change a gallon..... trick is to run it lean..... gave me the same performance as vp4 and runs just as cool.....
STLyamwar
07-25-2020 04:44 AM
MikeyBoyesq
08-10-2015 11:11 AM
Robinhood
07-13-2015 09:13 PM
Quick Reply: VP Ultimate 4 race fuel
