Warrior Pipe
Old Jul 25, 2003 | 02:21 PM
Warrior453's Avatar
Default Warrior Pipe
r alba pipes $hitty and thats y no one is replying to this post
Old Jul 25, 2003 | 02:24 PM
2000IAWarrior's Avatar
alba pipes are suppose to be good. if u get the kit its liek a 20% hp increase. like same as WB i may be gettint hat kit. nnow for 270 bucks u cant go wrong. pipe/ filter/jets/outware//torque stuffer/ everything you need. suppose to give good low end and u can adjust it like wb and supertrapp
Old Jul 25, 2003 | 02:27 PM
Warrior453's Avatar
whats the torqure stuffer what does it do and the out wear is like stickers right?
Old Jul 25, 2003 | 02:33 PM
touqe stuffer going in ur head pipe on the cyleder part gives more low end.. the outerware dont come w/ith the kit.. thought it did.. my bad.. the outwer ware is a nylon covering that goes over u filter and is a prefilter. gets a lot of the stuff out. and is water resistant. good idea to have.. cuts cleanin of u filter down..
Old Aug 1, 2003 | 02:30 AM
  #15
fenton's Avatar
I don't know if this helps but the Pro Circuit pipe is way over 100 db and the alba pipe is worse than stock.
That could be bad luck but my friend got the Alba Pipe and it was worse than stock; DG is also worse than stock. I personally like yosh or fmf PC IV w/powerbomb head. The Powrbomb is better than stock and is quiter.
Old Aug 4, 2003 | 02:32 PM
  #16
shlekter's Avatar
2000iawarrior how fast does your waarrior go?
Old Aug 4, 2003 | 02:38 PM
  #17
TrailBreaker70's Avatar
Actually I heard that HMF was one of the best pipes for the Warrior and it's a lot cheaper. That's what I'm gonna get.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 4, 2003 | 02:57 PM
  #18
stock down the highway w/baffle 61.6 down the highway w/o baffle 63-64.. it will go faster by next week when i get it piped and jetted.. and after i get my 14t front sprocket..
Old Aug 4, 2003 | 03:52 PM
  #19
warriorcj7's Avatar
What about Supertrapp for a warrior does it do any good?
Old Aug 4, 2003 | 03:56 PM
  #20
shlekter's Avatar
IM RUNNING A 15TOOTTH FRONT WITH A STOCK MOTOR~~`I WONDER IF TTHATS 2 HIGH...HEHEH.........WHAT OIL SHOULD I IRUN 2 KEEP MY MOTOR COOOL
